Samsung Galaxy S6 Vibrator Replacement
  1. Samsung Galaxy S6 Vibrator Replacement, Vibrator: step 1, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement, Vibrator: step 1, image 2 of 2
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
    • Press to eject the SIM card tray.
    • Don't press too hard or you may damage the SIM card tray.
  2. Samsung Galaxy S6 Vibrator Replacement: step 2, image 1 of 1
    • Remove the SIM card tray from the phone.
  3. Samsung Galaxy S6 Vibrator Replacement: step 3, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 3, image 2 of 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  4. Samsung Galaxy S6 Vibrator Replacement: step 4, image 1 of 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  5. Samsung Galaxy S6 Vibrator Replacement: step 5, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  6. Samsung Galaxy S6 Vibrator Replacement: step 6, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 6, image 2 of 2
    • Place the phone facedown.
    • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Lay the iOpener over the panel for about 60 seconds to loosen the adhesive around the edge of the glass.
    • Shift the iOpener to heat the remaining section of the panel for another 60 seconds.
  7. Samsung Galaxy S6 Vibrator Replacement: step 7, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 7, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 7, image 3 of 3
    • Attach a heavy-duty suction cup to the lower half of the rear glass panel.
    • Secure the suction cup by raising the hinged handle and flipping the latch to clamp both handles in place.
  8. Samsung Galaxy S6 Vibrator Replacement: step 8, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 8, image 2 of 2
    • The following steps involve using an opening pick to separate the rear panel from the midframe. If the adhesive is too strong, reapply heat with the iOpener.
    • Using the suction cup, apply pressure to the middle section of the panel while pulling up the lower edge by pivoting your wrist.
  9. Samsung Galaxy S6 Vibrator Replacement: step 9, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 9, image 2 of 2
    • Once you've opened a large enough gap, insert an opening pick between the rear glass and the midframe.
  10. Samsung Galaxy S6 Vibrator Replacement: step 10, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 10, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 10, image 3 of 3
    • Slide the opening pick around the bottom left corner of the rear glass panel.
  11. Samsung Galaxy S6 Vibrator Replacement: step 11, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 11, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 11, image 3 of 3
    • Slide the pick along the power button side of the phone.
  12. Samsung Galaxy S6 Vibrator Replacement: step 12, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 12, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 12, image 3 of 3
    • Slide the opening pick across the top of the phone.
  13. Samsung Galaxy S6 Vibrator Replacement: step 13, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 13, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 13, image 3 of 3
    • Slide the opening pick down along the volume buttons side of the phone.
  14. Samsung Galaxy S6 Vibrator Replacement: step 14, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 14, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 14, image 3 of 3
    • Pull up on the rear glass panel while holding down the midframe to separate the components.
    • If you encounter too much resistance from the adhesive, slide the opening pick under the glass a few more times.
  15. Samsung Galaxy S6 Vibrator Replacement: step 15, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 15, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 15, image 3 of 3
    • Insert an opening pick between the rear panel and the midframe.
    • Slide the pick along the top of the phone to loosen the remaining adhesive.
    • Twist the pick to separate the two pieces.
  16. Samsung Galaxy S6 Vibrator Replacement: step 16, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 16, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 16, image 3 of 3
    • At this point, the rear glass panel should be fully separated from the body of the phone, although the adhesive strip may be attached to both sides.
    • Pull the rear panel up and away to completely separate it.
    • Follow this guide to reinstall the rear glass.
  17. Samsung Galaxy S6 Vibrator Replacement: step 17, image 1 of 1
    • Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
  18. Samsung Galaxy S6 Vibrator Replacement: step 18, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 18, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 18, image 3 of 3
    • Firmly grasp the edge of the midframe assembly.
    • Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
  19. Samsung Galaxy S6 Vibrator Replacement: step 19, image 1 of 1
    • Lift the midframe assembly up to separate it from the rest of the phone.
  20. Samsung Galaxy S6 Vibrator Replacement: step 20, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 20, image 2 of 2
    • Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
  21. Samsung Galaxy S6 Vibrator Replacement: step 21, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 21, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 21, image 3 of 3
    • Insert a plastic opening pick between the case and the battery.
    • Be careful to keep the pick as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Push the pick further in to separate the battery from the phone.
    • If the battery is too strongly adhered for the opening pick, place a warm iOpener over the battery to loosen the adhesive.
    • Do not pry against the motherboard or you may damage the phone.
  22. Samsung Galaxy S6 Vibrator Replacement: step 22, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 22, image 2 of 2
    • Remove the battery from the phone.
  23. Samsung Galaxy S6 Vibrator Replacement: step 23, image 1 of 3 Samsung Galaxy S6 Vibrator Replacement: step 23, image 2 of 3 Samsung Galaxy S6 Vibrator Replacement: step 23, image 3 of 3
    • Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
  24. Samsung Galaxy S6 Vibrator Replacement: step 24, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 24, image 2 of 2
    • Use the flat end of the spudger to disconnect the home button connector.
  25. Samsung Galaxy S6 Vibrator Replacement: step 25, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 25, image 2 of 2
    • Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
  26. Samsung Galaxy S6 Vibrator Replacement: step 26, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 26, image 2 of 2
    • Disconnect the earpiece speaker assembly cable connector from the motherboard.
  27. Samsung Galaxy S6 Vibrator Replacement: step 27, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 27, image 2 of 2
    • Lift the camera-side end of the motherboard to separate it from the display frame.
    • Do not fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
  28. Samsung Galaxy S6 Vibrator Replacement: step 28, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 28, image 2 of 2
    • Disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
  29. Samsung Galaxy S6 Vibrator Replacement: step 29, image 1 of 2 Samsung Galaxy S6 Vibrator Replacement: step 29, image 2 of 2
    • Pry the vibrator up from the display assembly with the point of a spudger.
    • Push to pry up the vibrator and its spring-contact connector.
  30. Samsung Galaxy S6 Vibrator Replacement: step 30, image 1 of 1
    • Remove the vibrator.
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
System
1 Reputation
117 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 9
