This version may contain incorrect edits. Switch to the latest verified snapshot.
iPhone 5 Audio Control and Power Button Cable Replacement
  1. iPhone 5 Audio Control and Power Button Cable Replacement, Audio Control and Power Button Cable: step 1, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement, Audio Control and Power Button Cable: step 1, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement, Audio Control and Power Button Cable: step 1, image 3 of 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  2. iPhone 5 Audio Control and Power Button Cable Replacement, iSclack Opening Procedure: step 2, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement, iSclack Opening Procedure: step 2, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement, iSclack Opening Procedure: step 2, image 3 of 3
    • The next two steps demonstrate using the , a great tool for safely opening the iPhone 5 that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip to [invalid guide link].
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  3. iPhone 5 Audio Control and Power Button Cable Replacement: step 3, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 3, image 2 of 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on [invalid guide link].
  4. iPhone 5 Audio Control and Power Button Cable Replacement: step 4, image 1 of 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  5. iPhone 5 Audio Control and Power Button Cable Replacement: step 5, image 1 of 1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 5 Audio Control and Power Button Cable Replacement: step 6, image 1 of 1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  7. iPhone 5 Audio Control and Power Button Cable Replacement: step 7, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 7, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 7, image 3 of 3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  8. iPhone 5 Audio Control and Power Button Cable Replacement: step 8, image 1 of 1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  9. iPhone 5 Audio Control and Power Button Cable Replacement: step 9, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  10. iPhone 5 Audio Control and Power Button Cable Replacement: step 10, image 1 of 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  11. iPhone 5 Audio Control and Power Button Cable Replacement: step 11, image 1 of 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  12. iPhone 5 Audio Control and Power Button Cable Replacement: step 12, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 12, image 2 of 2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  13. iPhone 5 Audio Control and Power Button Cable Replacement: step 13, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 13, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 13, image 3 of 3
    • Use a plastic opening tool to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to [invalid guide link].
  14. iPhone 5 Audio Control and Power Button Cable Replacement: step 14, image 1 of 1
    • Remove the front panel assembly from the rear case.
  15. iPhone 5 Audio Control and Power Button Cable Replacement: step 15, image 1 of 1
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • If you have trouble peeling the battery up, use an iOpener or hair dryer to heat the rear case of the iPhone and soften the adhesive.
    • The plastic tab is fragile and may break. If your tab breaks before the battery is freed, refer to the following steps.
  16. iPhone 5 Audio Control and Power Button Cable Replacement: step 16, image 1 of 1
    • If the tab breaks off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    • This will soften the adhesive holding the battery, making it easier and safer to pry out of the case.
  17. iPhone 5 Audio Control and Power Button Cable Replacement: step 17, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 17, image 2 of 2
    • Use the plastic opening tool to gently pry the battery up, only at the outside edge of the phone. Prying anywhere else, especially near the logic board, may result in damage to the logic board.
    • If the battery doesn't pry easily out of the case, reheat and reapply the iOpener and try again.
    • Pry gently and evenly to avoid deforming the battery. A bent battery can be a fire hazard.
    • Do not pry at the top portion of the battery, you risk severing the volume control cables.
  18. iPhone 5 Audio Control and Power Button Cable Replacement: step 18, image 1 of 1
    • Remove the battery.
    • During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  19. iPhone 5 Audio Control and Power Button Cable Replacement: step 19, image 1 of 1
    • Use the tip of a spudger to pry the cellular data antenna cable connector up from its socket on the logic board, just above the speaker enclosure.
  20. iPhone 5 Audio Control and Power Button Cable Replacement: step 20, image 1 of 1
    • Remove the following two screws securing the top logic board bracket to the rear case:
    • One 1.5 mm Phillips screw
    • One 2.3 mm Phillips screw
  21. iPhone 5 Audio Control and Power Button Cable Replacement: step 21, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 21, image 2 of 2
    • Remove the bracket from the top of the logic board.
    • Be sure not to break off the tiny grounding tab that sticks up off of the bracket next to the rear facing camera.
    • On newer models, the bracket may be attached to the camera housing and will not come completely out.
  22. iPhone 5 Audio Control and Power Button Cable Replacement: step 22, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 22, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 22, image 3 of 3
    • Use the flat end of a spudger to disconnect the following three cables from the logic board:
    • Upper interconnect cable
    • Button assembly cable
    • Lower interconnect cable
  23. iPhone 5 Audio Control and Power Button Cable Replacement: step 23, image 1 of 1
    • Remove the two 1.3 mm Phillips screws from the inner top of the rear case.
  24. iPhone 5 Audio Control and Power Button Cable Replacement: step 24, image 1 of 1
    • Remove the single 1.2 mm Phillips screw remaining in the mid-section logic board bracket.
  25. iPhone 5 Audio Control and Power Button Cable Replacement: step 25, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 25, image 2 of 2
    • Remove the mid-section bracket from the logic board.
  26. iPhone 5 Audio Control and Power Button Cable Replacement: step 26, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 26, image 2 of 2
    • Use a spudger to pry the Lightning connector cable connector up from its socket on the logic board.
    • Gently peel the cable back and out of the way of the logic board.
  27. iPhone 5 Audio Control and Power Button Cable Replacement: step 27, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 27, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 27, image 3 of 3
    • Depress the SIM card release on the right side of the iPhone with a SIM card eject tool or a bent paperclip to eject the SIM card tray.
    • Alternatively, you can press the SIM card eject lever from the inside with the flat end of a spudger.
    • Remove the SIM card tray from the iPhone.
  28. iPhone 5 Audio Control and Power Button Cable Replacement: step 28, image 1 of 1
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Two 2.7 mm standoff screws.
    • These screws have a Phillips bit pattern, but we found the best removal tool to be a 2.5 mm flathead driver.
    • One non-magnetic 2.7 mm standoff screw
    • Be sure to put this screw back in its original position at the top of the logic board. A magnetized screw may interfere with the digital compass.
    • Reassembly hint: when putting the standoffs back in, use the tip of a spudger like a screwdriver to get them started.
  29. iPhone 5 Audio Control and Power Button Cable Replacement: step 29, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 29, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 29, image 3 of 3
    • Rotate the logic board assembly toward the battery side of the rear case.
    • Do not attempt to completely remove the logic board assembly from the rear case, yet; there is still one cable connected to the underside of the logic board.
    • The flash surround is adhered to the flash unit and the rear case. If it stays on the rear case remove with tweezers and mount it back on the flash unit.
    • Note: when reassembling your device, be sure that the lower interconnect cable is not tucked underneath the logic board.
  30. iPhone 5 Audio Control and Power Button Cable Replacement: step 30, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 30, image 2 of 2
    • Use the tip of a spudger to pry the Wi-Fi antenna cable connector up from its socket on the underside of the logic board.
  31. iPhone 5 Audio Control and Power Button Cable Replacement: step 31, image 1 of 1
    • Remove the logic board assembly from the rear case.
    • While your logic board is out of your phone, keep it on a grounded anti-static mat to prevent any damage to the circuitry.
  32. iPhone 5 Audio Control and Power Button Cable Replacement: step 32, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 32, image 2 of 2
    • Use the tip of a spudger to remove the rubber bumper from below the power button.
  33. iPhone 5 Audio Control and Power Button Cable Replacement: step 33, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 33, image 2 of 2
    • Remove the following screws from the metal bracket between the rear facing flash and camera windows:
    • One 2.9 mm standoff screw
    • This screw has a Phillips bit pattern, but we found the best removal tool to use is a 2.5 mm flathead driver.
    • One 1.9 mm Phillips screw
  34. iPhone 5 Audio Control and Power Button Cable Replacement: step 34, image 1 of 1
    • Remove the metal bracket between the rear facing flash and camera windows.
  35. iPhone 5 Audio Control and Power Button Cable Replacement: step 35, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 35, image 2 of 2
    • Use the tip of a spudger to flip the metal bracket holding the power switch away from the top of the rear case.
  36. iPhone 5 Audio Control and Power Button Cable Replacement: step 36, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 36, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 36, image 3 of 3
    • Press the power button into the rear case from the outside of the phone with the tip of a spudger.
    • Remove the power button.
  37. iPhone 5 Audio Control and Power Button Cable Replacement: step 37, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 37, image 2 of 2
    • Remove three screws securing the vibrator and vibrator bracket to the rear case:
    • One 1.7 mm Phillips screw
    • One 1.6 mm Phillips screw securing the vibrator to the top inside of the rear case.
  38. iPhone 5 Audio Control and Power Button Cable Replacement: step 38, image 1 of 1
    • Remove the vibrator and vibrator bracket from the rear case.
  39. iPhone 5 Audio Control and Power Button Cable Replacement: step 39, image 1 of 1
    • Remove the following screws securing the volume button and ringer switch brackets to the side of the rear case:
    • Two 1.8 mm Phillips screws
  40. iPhone 5 Audio Control and Power Button Cable Replacement: step 40, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 40, image 2 of 2
    • Use the tip of a spudger to pry the ringer switch bracket from the side of the rear case.
    • Remove the ringer switch.
  41. iPhone 5 Audio Control and Power Button Cable Replacement: step 41, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 41, image 2 of 2
    • Use a spudger to pry the volume button bracket from the side of the rear case.
    • Remove the volume buttons.
  42. iPhone 5 Audio Control and Power Button Cable Replacement: step 42, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 42, image 2 of 2
    • Use the tip of a spudger to slide the power button bracket up and to the left to unhook it from the metal hinge.
  43. iPhone 5 Audio Control and Power Button Cable Replacement: step 43, image 1 of 2 iPhone 5 Audio Control and Power Button Cable Replacement: step 43, image 2 of 2
    • Use the flat edge of a spudger to pry the cable up from the adhesive securing it to the rear case.
  44. iPhone 5 Audio Control and Power Button Cable Replacement: step 44, image 1 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 44, image 2 of 3 iPhone 5 Audio Control and Power Button Cable Replacement: step 44, image 3 of 3
    • Continue prying the audio control cable up from the rear case.
    • If your replacement part doesn't include the metal bracket, use a heat gun or hair dryer to soften the adhesive on the audio control cable and peel it off of the metal bracket with a spudger.
System
1 Reputation
117 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 30
