iPhone 5 Vibrator Replacement
  1. iPhone 5 Vibrator Replacement, Vibrator: step 1, image 1 of 3 iPhone 5 Vibrator Replacement, Vibrator: step 1, image 2 of 3 iPhone 5 Vibrator Replacement, Vibrator: step 1, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5 Vibrator Replacement: step 2, image 1 of 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. iPhone 5 Vibrator Replacement: step 3, image 1 of 3 iPhone 5 Vibrator Replacement: step 3, image 2 of 3 iPhone 5 Vibrator Replacement: step 3, image 3 of 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 Vibrator Replacement, iSclack Opening Procedure: step 4, image 1 of 3 iPhone 5 Vibrator Replacement, iSclack Opening Procedure: step 4, image 2 of 3 iPhone 5 Vibrator Replacement, iSclack Opening Procedure: step 4, image 3 of 3
    • The next two steps demonstrate using the , a great tool for safely opening the iPhone 5 that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip to [invalid guide link].
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  5. iPhone 5 Vibrator Replacement: step 5, image 1 of 2 iPhone 5 Vibrator Replacement: step 5, image 2 of 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on [invalid guide link].
  6. iPhone 5 Vibrator Replacement: step 6, image 1 of 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  7. iPhone 5 Vibrator Replacement: step 7, image 1 of 1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  8. iPhone 5 Vibrator Replacement: step 8, image 1 of 1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  9. iPhone 5 Vibrator Replacement: step 9, image 1 of 3 iPhone 5 Vibrator Replacement: step 9, image 2 of 3 iPhone 5 Vibrator Replacement: step 9, image 3 of 3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 5 Vibrator Replacement: step 10, image 1 of 1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  11. iPhone 5 Vibrator Replacement: step 11, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 5 Vibrator Replacement: step 12, image 1 of 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  13. iPhone 5 Vibrator Replacement: step 13, image 1 of 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  14. iPhone 5 Vibrator Replacement: step 14, image 1 of 2 iPhone 5 Vibrator Replacement: step 14, image 2 of 2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  15. iPhone 5 Vibrator Replacement: step 15, image 1 of 3 iPhone 5 Vibrator Replacement: step 15, image 2 of 3 iPhone 5 Vibrator Replacement: step 15, image 3 of 3
    • Use a plastic opening tool to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to [invalid guide link].
  16. iPhone 5 Vibrator Replacement: step 16, image 1 of 1
    • Remove the front panel assembly from the rear case.
  17. iPhone 5 Vibrator Replacement: step 17, image 1 of 1
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • If you have trouble peeling the battery up, use an iOpener or hair dryer to heat the rear case of the iPhone and soften the adhesive.
    • The plastic tab is fragile and may break. If your tab breaks before the battery is freed, refer to the following steps.
  18. iPhone 5 Vibrator Replacement: step 18, image 1 of 1
    • If the tab breaks off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    • This will soften the adhesive holding the battery, making it easier and safer to pry out of the case.
  19. iPhone 5 Vibrator Replacement: step 19, image 1 of 2 iPhone 5 Vibrator Replacement: step 19, image 2 of 2
    • Use the plastic opening tool to gently pry the battery up, only at the outside edge of the phone. Prying anywhere else, especially near the logic board, may result in damage to the logic board.
    • If the battery doesn't pry easily out of the case, reheat and reapply the iOpener and try again.
    • Pry gently and evenly to avoid deforming the battery. A bent battery can be a fire hazard.
    • Do not pry at the top portion of the battery, you risk severing the volume control cables.
  20. iPhone 5 Vibrator Replacement: step 20, image 1 of 1
    • Remove the battery.
    • During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  21. iPhone 5 Vibrator Replacement: step 21, image 1 of 1
    • Remove two screws securing the vibrator bracket to the rear case:
    • Single 2.3 mm Phillips screw
    • Single 1.7 mm Phillips screw
  22. iPhone 5 Vibrator Replacement: step 22, image 1 of 1
    • Remove the vibrator bracket from the rear case.
  23. iPhone 5 Vibrator Replacement: step 23, image 1 of 1
    • Remove the 1.6 mm Phillips screw securing the vibrator to the top inside of the rear case.
  24. iPhone 5 Vibrator Replacement: step 24, image 1 of 2 iPhone 5 Vibrator Replacement: step 24, image 2 of 2
    • Remove the vibrator from the rear case.
System
1 Reputation
117 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 10
