iPhone 5c Pentalobe Screws Replacement
  1. iPhone 5c Pentalobe Screws Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before we proceed, let's make sure you have the correct tools for the job.
    • iFixit's includes:
    • One 5-Point Pentalobe screwdriver
    • One #000 Phillips screwdriver
    • Two 3.8 mm "Liberation" Phillips screws
    • Are you ready to break the shackles of hardware oppression and liberate your iPhone? Let's rock!
  2. iPhone 5c Pentalobe Screws Replacement: step 2, image 1 of 1
    • Use the Pentalobe screwdriver to remove the two 3.8 mm Pentalobe screws near the dock connector.
    • The 5-Point Pentalobe screwdriver should only be used a limited number of times because it has the potential to strip the screws.
  3. iPhone 5c Pentalobe Screws Replacement: step 3, image 1 of 2 iPhone 5c Pentalobe Screws Replacement: step 3, image 2 of 2
    • Peel and remove the two 3.8 mm Phillips screws from the iPhone Liberation Card.
    • Be careful! Both the Phillips and Pentalobe screws are really small. How small? See for yourself, and be careful not to drop them!
  4. iPhone 5c Pentalobe Screws Replacement: step 4, image 1 of 1
    • Insert the two 3.8 mm Phillips screws into the screw holes using the provided #000 Phillips screwdriver.
    • Huzzah! Your iPhone is now liberated from those pesky "Pentalobular" screws.
System
1 Reputation
117 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 15
