Introduction
Use this guide to replace the display assembly on your iPhone 5c.
The display assembly is made up of the LCD, front glass, digitizer, front-facing camera and sensor cable assembly, and home button assembly.
To replace a bare front panel, made up of only the LCD and front glass, you need to be on [invalid guide link].
Video Overview
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
The top suction cup should rest just above the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
Skip the next three steps and continue on to [invalid guide link].
Press a suction cup onto the screen, just above the home button.
Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
In a pinch, you can use an unopened canned beverage to hold the display.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
2 Guide Comments
Apple products are really good and comfortable with users. It is easy to use and understanding but just because it's all a gadget so some basic problem with Apple is common things. And according to me, because I am also an Apple user sometimes I face issues with iTunes so I can say that little problem is a very common thing. And other hands we do not know about some basics thing of iTune for more information visit this link
[|iTunes Tech Support Number]
se����0
This steps are really helpful for us . if i talk about display then I always recommended iPhone because it’s display is really strong .
